Help-me, please I can't copy and paste nodes
Good evening, I haven’t been able to copy and paste my nodes, I can select them, but when I press CTRL C and CTRL V nothing happens, it just looks like this out of nowhere
Version 0.231.3
PADRÃO
Docker, hospeded in digitalocean
hello @PedroHenrique26
First of all, check your keyboard layout, it should be English-like (some shortcuts do not work in some layouts). And update the n8n, you have too old version.
Não tem a ver com o teclado, horas pega, horas não, aparece o “copied” mas não cola no fluxo, às vezes sim, às vezes não, o que pode ser?
Sometimes when copy and pasting between very different versions you can get some strange behavior.
Will need to see more information on what is actually happening when you said this in your original message. No pictures or anything came through
