Please check this script from a code node and help me to understand why is it that there is a valid input to the node, but no output is coming out, not even an error. This is the script:
const item = $json;
// Verifica que item tenga la estructura esperada directamente
if (!item?.input || !item?.sessionId) {
throw new Error(“Formato de entrada inválido. Se requieren ‘input’ y ‘sessionId’”);
// Devuelve el output estructurado correctamente
return {
json: {
input: item.input,
sessionId: item.sessionId,
debug: “directo_desde_webhook”
! Captura de pantalla 2025-06-13 a la(s) 7.57.00 a.m.|690x371
