"help my work flow is possessed"
Hey n8n team, I think my work flow might be haunted. Here’s the paranormal activity I’m dealing with
Work flow : Webhook-> filter - > 5 Different API calls - > Database update
So, random nodes activate by themselves when no trigger occurred. Also, Database shows entries as 3am when no user is active and sometimes changes happen before the Webhook trigger timestamp
These are my stack
N8n 1.34.1 (Docker on digital ocean)
PostgreSQL 13
Using n8n’s built-in scheduling
hey @Najemdeen_Sulaimon you should share your workflow, so we can see what is causing that *paranormal activity.
