Hi everyone ,
I’m working on a complex automation use case using n8n, and I’ve hit a point where I need help from more experienced builders to take it further, especially in handling files, binary data, and integrating with AI.
What I’m Trying to Build:
An AI-powered framework to receive files with different extensions(pdf,docx, XLS, PNG, JPEG,…) and I want to handle these file submissions (I am using n8n built-in form) automatically prepare professional case reports, based on uploaded documents and assignments. The workflow follows multiple structured phases:
- *Receive files
- Extract data tasks
Current Inputs:
Through an n8n
form or webhook, I receive JSON like this:
I also push metadata about the files for the AI agent — like role (plaintiff/defendant), extraction type (OCR vs summarisation), etc.
What I Have Working:
Form-based data collection and file intake
JSON cleanup and metadata normalisation using Code node
AI-ready file metadata for extraction tasks (e.g., OCR)
Where I Need Help:
How to properly manage and reuse binary data across nodes (esp. splitting and merging)
What’s the best pattern for processing multiple files per input row using
binary
data?Anyone implemented file-type-dependent flows (e.g., PDF → Text AI, JPEG → OCR) reliably?
Ideas for gracefully handling large or many files in a single submission
Any AI integration best practices from the n8n side (OpenAI vision, Claude, etc.)
Should I offload heavy file processing (AI or storage) outside n8n?
Notes:
I’m using:
Function
&Code
nodes to handle logic- Planning to use an AI agent via GPT/OpenAI.
Any advice, example flows, or help would be appreciated.
If someone’s open to collaborating or building together — I’m open to that too !
Thanks in advance!
