Help needed to activate a license key on a self-hosted n8n
My Problem
I’m hoping someone can clarify an issue I’m having to activate a license key.
I requested a key to unlock the “Registered Community Edition” features in my n8n Community instance—specifically Workflow History, Editor Debugging, Folders, and Execution Search, with lifetime access.
However, I can’t validate the key.
  • In my self-hosted instance there is no menu path Settings → Usage & Plan → Enter License Key → Activate.
  • So I updated my stacks in Portainer and added the line
    - N8N_LICENSE_KEY=<my_key_from_email>
    to all services (editor, worker, webhook, mcp).
  • I redeployed each stack, but nothing changed—the paid features are still disabled.
  • n8n version: 1.98.1
  • Database: postgres
  • Running n8n via Docker
  • Operating system: Linux
@Caio_Pereira
Do you have this set to true?
N8N_HIDE_USAGE_PAGE=false
It was set TRUE. Changed to FALSE and problem SOLVED. Thank u
I have n8n allocated in a Hostinger VPS, which are the steps to set N8N_HIDE_USAGE_PAGE=false? Ubuntu/Linux
Thanks
