Help needed urgently
evolution API credentials (token + endpoint URL). http://31.97.145.116:8080/manager/instance/7aa93b1a-dc7d-4cec-8c8d-081c04553659
password : 123456.+az1
Your current chatbot flow (even if incomplete). n8n.io - Workflow Automation
[email protected]
Pass: NextZombie0912
Sample property images (or links where they’re hosted). attached
Basic property details (rent, location, size, availability). i attached 2 prompts, one in spanish(original) and one in english(traduction for you) there is all the information. also i will attached another txt (info.txt) with more information about the rents
A test WhatsApp number we can use to check the bot responses. its already connected in evolution +525513886934
This workflow is suppose to send image to Whatsapp but there are some glitch can anyone guide me through or help me out
Be careful while sharing credentials of your N8N instance. Anyone can go to credentials tab and can get access to all of your credentials and can perform unintended action.
