Help plese problem
Hi everyone,
I’m still having the same issue: sending emails doesn’t work. My Google Drive and Google Sheets integrations work fine, but when I try to add Gmail I can’t find any option to connect a URL or configure my email.
As you can see in the screenshot, the Google Cloud side shows a Client ID and Client Secret, but for Gmail I don’t have anything like that.
If anyone can help or has an idea, please let me know — or feel free to contact me on Discord: alexrigal.
Thanks in advance!
Hey, what’s your n8n version? What happens if you click on the Sign in button - it might be expected on the cloud version, I’m not sure.
Hello @Saladine , you need configure this Gmail node with Google Cloud Service Account and enable the Gmail API.
Go to API & Services then select credentials (here create OAuth2 app), it will give you ClientID and Secrets.
Then under Enabled APIs & services, check and make sure GMail API is enabled.
This is how you can configure GMail integration in n8n.
In this video, I showed above steps, you can follow the same just enable different API:
Watch the video
Hi,
This link from google cloud documentation would definitely help. Getting started  |  Cloud APIs  |  Google Cloud , once you have enabled Gmail API, you can copy client ID and secret for gmail API from google workspace
If you are struggling with configuring Credentials and need help finding the values, check out this video from n8n about this:
