Hello n8n community,
I hope you’re doing great!
I am currently building an AI Agent-based flow in n8n, aimed at handling dynamic, multi-turn conversations through WhatsApp and integrating with Airtable to fetch product information for my brand, MARAS GOURMET.
I would greatly appreciate your help, as I am facing some challenges regarding conversation continuity.
What I have built so far:
- Trigger: WhatsApp webhook receiving user messages.
- AI Agent: Powered by OpenAI (gpt-4-turbo) with a detailed custom system prompt.
- Memory: Using “Simple Memory” (
Memory Buffer Window) with a session tied to the user’s WhatsApp number. - Airtable Integration: Searching products based on user queries.
- WhatsApp Response: Sending back AI-generated replies dynamically.
The AI Agent starts the conversation correctly (asking for product information), but does not maintain a natural multi-turn dialogue.
Instead of smoothly collecting data step-by-step (email, product interest, offer pricing, etc.), it behaves more like a “one-shot” interaction: asking once, then stopping.
Even though I have:
- Configured a
Simple Memorynode withcontextWindowLength = 7. - A system prompt that instructs it to move through the conversation progressively.
- Airtable working correctly for product lookup.
➔ The conversation is still not flowing naturally across multiple steps.
Each user response seems isolated instead of building on the previous ones.
Key questions where I need help:
- How can I instruct the AI Agent to truly maintain context and progress through the conversation logically?
(e.g., Ask for product → confirm → offer pricing → offer purchase.) - Is there a best practice for “slot filling” behavior (email, product, location, etc.) inside an n8n AI Agent flow?
- Is Simple Memory enough for this?
Or should I implement a different memory type (like vector memory, Redis memory, or manual slot tracking)? - Are there working examples of fully conversational flows (multi-turn, slot-filling, dynamic branching) that I could reference?
- Any optimization tips for System Instructions to ensure the agent acts like a real human conversation, not just answering and stopping?
Technical details:
- n8n Version: (your version here, e.g., 1.29.1)
- Hosting: (Self-hosted / n8n Cloud — specify)
- Language Model: OpenAI GPT-4 Turbo
- Memory Node: Memory Buffer Window (context length 7)
- Trigger: WhatsApp API (using WhatsApp Trigger node)
- Database: Airtable (Personal Access Token)
