Help setting up webhook with Memberful
Hello, I’m trying to set up a connection to Memberful using their webhooks, but I’m a bit confused on the differing terminology between the two and can’t seem to get it working. Does anyone have an idea what I’m doing wrong? Thanks for helping out a noob, I promise I searched around first!
Hi @davidkingham
I am not familiar with Memberful, but at a quick glance it doesnt seem you need to add the header auth. Can you remove the Auth and try it?
Hi @davidkingham , You need see what Memberful send to N8N webhook in the header, like this
if I send a header is ‘aa:aa’ then webhook will recive a header is ‘aa:aa’
curl https://example.com/webhook-test/a8a9a92a-9b23-4925-8a1d-b63b26f2ddff -H 'aa: aa'
So, you can check what key is Memberful send SECRET with, then change your Header Auth account Name to that key
