I am trying to set up a POST request including data from a previous trigger note. I want to use information about a new order from WooCommerce (trigger) within a POST request towards an API, including information from the WooCommerce Trigger json output (e.g. Name or E-Mail of the customer).
I am really struggling with formulating the POST request with the body parameters, the request body should look like this:
"lockIds": [
XXX
"receiverName": "FIRSTNAME LASTNAME",
"receiverEmailOrPhoneNumber": "[email protected]",
"message": "Some random message",
"permissionType": 1,
"permissionTimeProfile": {
"repetitionType": 0,
"items": [{
"startDate": "DATESTART",
"endDate": "DATENEND"
I try to recreate this with the HTTP request Node, but I fail. Name, E-Mail and the dates should be transmitted from the WooCommerce trigger.
Bad Request
Please share the workflow
"status": "rejected",
"reason": {
"name": "StatusCodeError",
"statusCode": 400,
"error": {
"errorLiteral": "Generic.BadRequest",
"errors": {...}, // 2 keys
"type": "https://xxxxx.de/errors#Generic.BadRequest",
"title": "Validation error",
"status": 400,
"detail": "One or more validation errors occurred",
"extensions": {}
- n8n version: 0.172.0
- Database you’re using (default: SQLite):
- Running n8n with the execution process [own(default), main]:
- Running n8n via: Docker
