I’m trying to load data from a bunch of SQL tables into a vector database so I can power a chatbot with it. The issue I’m running into is that my current workflow fetches data from each table one by one and merges it all into one big JSON. I’d rather keep each table’s data separate and add some metadata to each one.
Also, when I try to load a pretty large dataset (38k records) into the vector store, it takes forever and usually ends up erroring out with something like “maximum call stack size exceeded.” Any ideas on how to make this faster and more efficient?
- n8n version:
- Database (default: SQLite):
- Operating system:
