Thanks for your answer @jan,
still getting an error with the code-node but will test around in order to get it
Problem in node ‘Code2‘
I’m testing in desktop on mac.
Cannot read properties of undefined (reading ‘notif’) [line 2]
TypeError: Cannot read properties of undefined (reading 'notif')
at /private/var/folders/9k/5j8f1sl97zdblz5yqzrs89wc0000gn/T/AppTranslocation/8C8026CD-0A55-429A-80C1-3C0DF51C26E0/d/n8n.app/Contents/Resources/app/node_modules/n8n-nodes-base/dist/nodes/Code:2:40
at /private/var/folders/9k/5j8f1sl97zdblz5yqzrs89wc0000gn/T/AppTranslocation/8C8026CD-0A55-429A-80C1-3C0DF51C26E0/d/n8n.app/Contents/Resources/app/node_modules/n8n-nodes-base/dist/nodes/Code:5:2
at VM2 Wrapper.apply (/private/var/folders/9k/5j8f1sl97zdblz5yqzrs89wc0000gn/T/AppTranslocation/8C8026CD-0A55-429A-80C1-3C0DF51C26E0/d/n8n.app/Contents/Resources/app/node_modules/vm2/lib/bridge.js:485:11)
at Sandbox.run (/private/var/folders/9k/5j8f1sl97zdblz5yqzrs89wc0000gn/T/AppTranslocation/8C8026CD-0A55-429A-80C1-3C0DF51C26E0/d/n8n.app/Contents/Resources/app/node_modules/vm2/lib/nodevm.js:426:23)
at Sandbox.runCodeAllItems (/private/var/folders/9k/5j8f1sl97zdblz5yqzrs89wc0000gn/T/AppTranslocation/8C8026CD-0A55-429A-80C1-3C0DF51C26E0/d/n8n.app/Contents/Resources/app/node_modules/n8n-nodes-base/dist/nodes/Code/Sandbox.js:53:42)
at Sandbox.runCode (/private/var/folders/9k/5j8f1sl97zdblz5yqzrs89wc0000gn/T/AppTranslocation/8C8026CD-0A55-429A-80C1-3C0DF51C26E0/d/n8n.app/Contents/Resources/app/node_modules/n8n-nodes-base/dist/nodes/Code/Sandbox.js:30:62)
at Object.execute (/private/var/folders/9k/5j8f1sl97zdblz5yqzrs89wc0000gn/T/AppTranslocation/8C8026CD-0A55-429A-80C1-3C0DF51C26E0/d/n8n.app/Contents/Resources/app/node_modules/n8n-nodes-base/dist/nodes/Code/Code.node.js:74:39)
at Workflow.runNode (/private/var/folders/9k/5j8f1sl97zdblz5yqzrs89wc0000gn/T/AppTranslocation/8C8026CD-0A55-429A-80C1-3C0DF51C26E0/d/n8n.app/Contents/Resources/app/node_modules/n8n-workflow/dist/src/Workflow.js:645:51)
at /private/var/folders/9k/5j8f1sl97zdblz5yqzrs89wc0000gn/T/AppTranslocation/8C8026CD-0A55-429A-80C1-3C0DF51C26E0/d/n8n.app/Contents/Resources/app/node_modules/n8n-core/dist/src/WorkflowExecute.js:562:68
