I have an existing workflow that is already mostly working. Current behavior: I drop a file into Folder 1. The workflow processes that file. The processed/new file goes to Folder 2. The original file gets moved to Folder 3. The problem: Right now, this only works properly if I place one file at a time into Folder 1. If I drop 2, 3, or more files into Folder 1 at the same time, the workflow tries to process them all simultaneously, which causes the workflow to take the 2 or 3 or however mnay files and combines the results of all the files into one big file. What I want: I want to be able to drop multiple files into Folder 1 at once. The workflow must not process them all in parallel Instead, it should treat Folder 1 like a queue and process the files strictly one at a time, in sequence. Only after one file has fully completed the workflow should the next file begin processing. PLease can anybody help me with this?
n8n version: latest version
Database (default: SQLite):
Running n8n via (Docker, easypanel, ngrok and hetzner.
Operating system: windows 11
