Help with a workflow-Instagram scraper
Can someone tell me why this workflow is not working?
It’s supposed to take my Instagram post, scrape them, and send them to TikTok, but it’s not doing that. It used to, I made no changes and then it stopped sending them to TikTok.
@Mike_Volkin I dont think anyone can access or view your workflow directly from the URL you shared.
Hi @Mike_Volkin You have shared your instance URL which cannot/shouldn’t be accessed by community, consider sharing your workflow JSON and the problem you are facing, although i recommend using APIfy for scraping contents from social media platforms but let us know your workflow!
