Help with an automation regarding payhero table and API
Hi, i have a website called payhero which has all the info in a table format for new employees, they gave me an API. I want to know how I can build a template to have log in, check the table for a date and post on slack. I want to be able to check the start date of staff and birthdays then advertise on slack *happy birthday ___ or happy anniversary" daily.
Havent started yet, want to know if its possible with an app intergration that is not there (but have API for the website)
I assume you are talking about this PayHero API.
From what I can see, this request will get you the list of employees, then you will parse the ā€œbirth_dateā€ fields and compare them to current date and for those found you will send slack message. The login is explained on corresponding api call page.
