Help with correct call pricing for Retell AI (Twilio DACH region)
Hi everyone,
I’m trying to figure out the correct pricing for Retell AI when using Twilio. I often see something like €0.12/min mentioned, but Twilio shows many different prices depending on route and country.
I specifically need the rates for calls from a German number to Switzerland, Germany, and Austria, and I assume there are different prices for landline vs. mobile.
Does anyone know what the realistic per-minute costs are that I should calculate with?
Thanks in advance!
I see for Germany they list $0.10/min and for Austria and Switzerland I couldn’t find prices, which probably means they are very similar to the rest of the EU.
Here’s an estimate from Claude with deep thinking too if it helps:
Voice Engine (ElevenLabs):     $0.070/min
LLM (GPT-4o mini):            $0.006/min
Retell Twilio:                $0.015/min
Germany calling rate:         $0.100/min
TOTAL:                        $0.191/min
To be 100% sure, I would contact the respective vendors directly, as you will at least have information from the source :handshake:
Feel free to mark as solution if it helps
