Help with Generating 1000 Verified Leads Daily from LinkedIn Sales Navigator?
I’m setting up an automated lead generation workflow using n8n to pull 1,000 new leads daily from LinkedIn Sales Navigator. The goal is to ensure these leads are unique, with no duplicates across days, and later add an email verification step using Instantly.ai. My current workflow uses Apify to scrape Sales Navigator URLs and pushes results to Google Sheets and Instantly.ai. However, I’m struggling to ensure 1,000 fresh leads daily without repeats. Should I rely on LinkedIn scraping or use Apollo’s database for stability? Has anyone built a similar system? How do you handle deduplication across days? Any advice on workflows or tools would be appreciated.
Thanks for the response mate
Also for the email verifier which took should I use any idea
Thanks once again
