Hello, now I am doing an automation where I have to send different messages or notifications to different people because they are messages with different reasons, but at the time of sending I need a solution to only send the new messages and not all the results, then I need some guidance to use the split batch node or the code node to give an instruction to send the last result which in this case is when a sheet file is modified which is where the message is taken from, I would appreciate your suggestions and health help each other
Hi, unfortunately it’s not very clear what you need. Please share your workflow and any errors you encounter. If you have not started, I would recommend posting to “help me build my workflow”.
Regards
J.
