Help with not recognising binary data
Dropbox upload file node does not seem to recognise that it has binary input data? I have tried this with different cloud drive services like one drive, and I keep receiving this error.
Here is where the workflow error is. (Query and create a folder are for making the folder to put the video in)
Hi @aripatel123
The problem is that you linked the upload a file node to two branches..
So What happens is that the node runs twice:
  1. once from the first branch that creates the folder,
  2. and once from the branch that generates the image.
The solution is to just merge the two branches then link it with the upload a file node
