Help with pagination | Better solution please?
I know there’s been a bunch of threads on pagination, and with all of them I’ve tried to implement the fixes but couldn’t seem to find anything that worked.
Basically I’ve got a scraping tool that paginates with, with the code node checking whether its the final page or not, and using an if node to loop back around. The problem is that the data then comes out in separates runs.
I needed the data in a single run to then go through a second loop which will further extract data for individual leads, this can’t be done since after the first run the ‘done’ stays open, and all future data flows straight through.
The fix?
Use a code node to aggregate all the data coming out (4 x all the data for example), then mark the first run with a secret code, and filter out anything not with this code, I can then pass this run onto the actual loop.
Funny solution, but has anyone else found a better solution, want to know for future reference.
I should add that for some reason there seems to be a bug that the final results shows 152 items for example, but in reality there is only 38. Strange.
Example Workflow
  • n8n version: 1.93
  • Operating system: Mac
theres an option in the http node to handle pagination
Yes but the pages being queried don’t have a simple response in order to parse through and confirm further pages, otherwise I would’ve use it.
