Hey guys, I am running n8n on a docker/caddy server hosted on digital ocean. I am trying to setup queuing using workers, redis, and postgres. I have everything setup and loaded with no errors. Workflows will be added to the queue but are never removed and actioned on. Any ideas. yml below:
services:
caddy:
image: caddy:latest
restart: unless-stopped
ports:
- “80:80”
- “443:443”
volumes:
- caddy_data:/data
- ${DATA_FOLDER}/caddy_config:/config
- ${DATA_FOLDER}/caddy_config/Caddyfile:/etc/caddy/Caddyfile
dns:
- 8.8.8.8
- 8.8.4.4
- 1.1.1.1
postgres:
image: postgres:13
container_name: postgres
environment:
- POSTGRES_USER=n8n
- POSTGRES_PASSWORD=test
- POSTGRES_DB=n8n
volumes:
- postgres_data:/var/lib/postgresql/data
restart: always
n8n:
image: docker.n8n.io/n8nio/n8n
restart: always
ports:
- 5678:5678
environment:
- N8N_HOST=${SUBDOMAIN}.${DOMAIN_NAME}
- N8N_PORT=5678
- N8N_PROTOCOL=https
- NODE_ENV=production
- WEBHOOK_URL=https://${SUBDOMAIN}.${DOMAIN_NAME}/
- GENERIC_TIMEZONE=${GENERIC_TIMEZONE}
- N8N_API_ENABLED=true
- N8N_BASIC_AUTH_ACTIVE=true
- N8N_BASIC_AUTH_USER=test
- N8N_BASIC_AUTH_PASSWORD=test
- EXECUTIONS_DATA_MAX_AGE=1209600000
- EXECUTIONS_DATA_PRUNE_MAX_COUNT=1000
- N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=false
- N8N_RUNNERS_ENABLED=true
- EXECUTIONS_MODE=queue
- QUEUE_BULL_REDIS_HOST=redis
- QUEUE_BULL_REDIS_PORT=6379
- N8N_RELEASE_DATE=2025-03-06T00:00:00Z
- N8N_DB_TYPE=postgresdb
- N8N_DB_POSTGRESDB_HOST=postgres
- N8N_DB_POSTGRESDB_PORT=5432
- N8N_DB_POSTGRESDB_DATABASE=n8n
- N8N_DB_POSTGRESDB_USER=n8n
- N8N_DB_POSTGRESDB_PASSWORD=test
- N8N_ENCRYPTION_KEY=test
volumes:
- n8n_data:/home/node/.n8n
- ${DATA_FOLDER}/local_files:/files
depends_on:
- postgres
dns:
- 8.8.8.8
- 8.8.4.4
- 1.1.1.1
redis:
image: redis:6
restart: always
volumes:
- redis_data:/data
command: [“redis-server”, “–appendonly”, “yes”]
worker:
restart: always
depends_on:
- redis
- postgres
environment:
volumes:
caddy_data:
external: true
n8n_data:
external: true
redis_data:
postgres_data:
