We are looking for an option to integrate n8n inside our system, including custom design, using features that are more focused on our users’ type, and add triggers and actions that are relevant to our system.
However our system is built in react.
Are there any guidelines / solutions from community / n8n regarding how to do this correctly?
currently our options are:
If there’s any ready solution to embed in react - look for them.
Forking n8n to a different repo => customize it to our needs in Vue => import it as a micro-frontend service into our react application (are there any guildlines for this, too?)
Build the UI from scratch, using mostly n8n backend capabities
As embedding n8n needs a license have you already asked our licensing team if they have any examples or pointers they can share from other embed customers or for possible help setting up a PoC? Could be a good way to find the answers you are after.
