Help with Self-Hosting on AWS
Hey all,
Hope you can help, i’ve followed the instructions to install n8n on AWS, but i’m falling down at the final hurdle.
I can’t access port the app through the web, i have to change the “HTTPS” to “HTTP” and then i get an error :-
" Your n8n server is configured to use a secure cookie,
however you are either visiting this via an insecure URL, or using Safari."
i don’t really want to switch it off, so how do you go about activating the “HTTPS” in AWS?
Thanks
Steven
