Help With Twitter Automation
Hi guys
I am trying to get only the newest tweets and then publish them on Telegram.
For some reason my code is not working. Can you please help me with this node?
I am attaching the node code below. I have checked the resources that exist currently and copied the code from them but it does not work for me as the same tweet keeps being published over again.
  "nodes": [
      "parameters": {
        "chatId": "-1001541294502",
        "text": "=👇 AMC تغريدة جديدة من \n{{$node[\"Function\"].json[\"tweet_url\"]}}",
        "additionalFields": {}
      "name": "Send Telegram on AMC Group",
      "type": "n8n-nodes-base.telegram",
      "typeVersion": 1,
      "position": [
        1040,
        690
      "notesInFlow": true,
      "credentials": {
        "telegramApi": "AMC Bot"
      "notes": "Channel: -1001303719248\nAMC Group: -1001196072954"
      "parameters": {
        "operation": "search",
        "searchText": "arabmarketcap",
        "limit": 2,
          "includeEntities": true,
          "resultType": "recent"
      "name": "Twitter",
      "type": "n8n-nodes-base.twitter",
      "typeVersion": 1,
      "position": [
        340,
        570
      "credentials": {
        "twitterOAuth1Api": "AMC Twitter"
      "parameters": {
        "triggerTimes": {
          "item": [
              "mode": "everyMinute"
      "name": "Cron",
      "type": "n8n-nodes-base.cron",
      "typeVersion": 1,
      "position": [
        150,
        570
      "parameters": {
        "functionCode": "/*\nconst new_items = [];\nconst data = this.getWorkflowStaticData('node');\n\ndata.ids = data.ids || [];\n\nfor (var i=0; i<items.length; i++) {\n  if (data.ids.includes(items[i].json.id)) {\n    break;\n  } else {\n    new_items.push({json: {id: items[i].json.id, url: items[i].json.url, tweet: items[i].json.tweet, username: items[i].json.username, photo: items[i].json.photo, name: items[i].json.name, color: items[i].json.color}});\n  }\n}\n\ndata.ids = items.map(item => item.json.id)\nreturn new_items;\n*/\nconst staticData = getWorkflowStaticData('global');\nconst newTweetIds = items.map((item) => item.json['Tweet ID']);\nconst oldTweetIds = staticData.oldTweetIds;\n\nif (!oldTweetIds) {\n  staticData.oldTweetIds = newTweetIds;\n  return items;\n}\n\nconst actualNewTweetIds = newTweetIds.filter((id) => !oldTweetIds.includes(id));\nconst actualNewTweets = items.filter((data) =>\n  actualNewTweetIds.includes(data.json['Tweet ID'])\n);\nstaticData.oldTweetIds = [...actualNewTweetIds, ...oldTweetIds];\n\nreturn actualNewTweets;\n"
      "name": "Function",
      "typeVersion": 1,
      "position": [
        680,
        570
      "alwaysOutputData": true,
      "notes": "Returns new tweets"
      "parameters": {
        "keepOnlySet": true,
        "values": {
          "string": [
              "name": "tweet_screename",
              "value": "={{$node[\"Twitter\"].json[\"user\"][\"name\"]}}\n"
              "name": "tweet_text",
              "value": "={{$json[\"text\"]}}\n"
              "name": "tweet_id",
              "value": "={{$json[\"id\"]}}\n"
              "name": "tweet_url",
              "value": "=https://twitter.com/{{$node[\"Twitter\"].json[\"user\"][\"screen_name\"]}}/status/{{$node[\"Twitter\"].json[\"id_str\"]}}"
        "options": {
          "dotNotation": true
      "name": "Store Tweet Info",
      "type": "n8n-nodes-base.set",
      "typeVersion": 1,
      "position": [
        520,
        570
      "parameters": {},
      "name": "NoOp",
      "type": "n8n-nodes-base.noOp",
      "typeVersion": 1,
      "position": [
        1050,
        500
      "parameters": {
        "conditions": {
          "string": [
              "value1": "={{$node[\"Function\"].json[\"tweet_id\"]}}",
              "operation": "isEmpty"
      "name": "IF new tweets",
      "type": "n8n-nodes-base.if",
      "typeVersion": 1,
      "position": [
        840,
        570
  "connections": {
    "Twitter": {
      "main": [
            "node": "Store Tweet Info",
            "type": "main",
            "index": 0
    "Cron": {
      "main": [
            "node": "Twitter",
            "type": "main",
            "index": 0
    "Function": {
      "main": [
            "node": "IF new tweets",
            "type": "main",
            "index": 0
    "Store Tweet Info": {
      "main": [
            "node": "Function",
            "type": "main",
            "index": 0
    "IF new tweets": {
      "main": [
            "node": "NoOp",
            "type": "main",
            "index": 0
            "node": "Send Telegram on AMC Group",
            "type": "main",
            "index": 0
Welcome to the community @alijdev
Are you activating the workflow? Because static data only is persisted when the workflow is activated.
Thanks for answer and sorry for late reply, We are actually using active mode for the workflow and the same problem
Hey @Essam_Aldeen!
Welcome to the community :sparkling_heart:
I took a look at the workflow shared above, and the variables are different in the Set node and the Function node. You can use this workflow: https://n8n.io/workflows/875
You will have to update the Search Text in the Twitter node and replace the Mattermost node with a Telegram node. You don’t need to use the IF node in the workflow. The Function node will only return new items.
