Help with workflow - Non profit
Looking for Advice
I’m doing pro bono work for a non-profit that needs to do analysis of their mobile lines. I designed the architecture outline, and I’ll be using n8n for the automation and Claude for the analysis and data aggregation. Has someone worked in a similar project?
PDF dropped in Drive > Trigger Alerts > Move to Claude For Analysis > Excel Created > Dropped Into Drive
Hello Arindam1,
First, Understanding Your Project Requirements
I’ve worked on something similar like this project before. You are working on an interesting project for a non-profit organization, leveraging automation and AI for analyzing their mobile lines data. You’ve outlined a workflow that involves using n8n for automation and Claude for data analysis and aggregation. I have assessed your suggested workflow and given inputs that may be helpful to you
Assessing Your Workflow
To ensure your project is successful, here are a few considerations:
  • PDF Processing: Make sure you’re handling different types of PDFs (scanned, text-based, etc.) appropriately. You might need OCR (Optical Character Recognition) for scanned PDFs.
  • Trigger Alerts: Define clear criteria for when alerts should be triggered. This could be based on specific data thresholds or anomalies detected during analysis.
    Idempotency: Also ensure that you implement checks for repeated drops of the same pdf files that have already been worked on successfully. Ensure that, there is a check to flag when a pdf has already been worked on successfully so that repeated drops of the same pdf doesn’t go through the entire automation again.
  • Claude Integration: Ensure you’re optimizing your input to Claude for the best results. This might involve preprocessing data or structuring it in a way that Claude can analyze effectively.
  • Excel Report Generation: Consider the structure and content of your Excel reports. Automating the formatting and ensuring that the data is presented in a useful way will be important.
Potential Enhancements
To take your project to the next level, you might want to consider a few enhancements:
  • Data Validation: Implementing a step to validate the data being processed could help catch errors early on.
  • Error Handling: Developing a robust error handling mechanism within your n8n workflow will be crucial. This could involve retry mechanisms, logging errors, and alerting you or the non-profit team to issues.
  • Security and Privacy: Given that you’re working with potentially sensitive data, ensure that your workflow adheres to any relevant data protection regulations.
Next Steps
To further refine your project, it might be helpful to:
  1. Share more details about the specific analysis Claude will be performing.
  2. Discuss any challenges you’ve faced so far in designing or implementing this workflow.
  3. Explore how you plan to monitor and maintain this workflow over time.
I’m here to help with any follow-up questions or to provide more specific guidance based on your project’s needs. What would you like to focus on next?
Here’s my email for quicker conversations: brainstormbright@gmail.com
