Hello, I am desperate
I tried to upgrade my n8n version
ubuntu vps
docker pull n8nio/n8n
Stop current setup
sudo docker-compose stop
Delete it (will only delete the docker-containers, data is stored separately)
sudo docker-compose rm
Then start it again
sudo docker-compose up -d
now all my workflows is gone,
when i try to install again i get the warning…
“WARNING: The DATA_FOLDER variable is not set. Defaulting to a blank string.”
but before everything was ok
see below:
