High Concurrency PostgreSQL UPSERT Deadlocks & Connection Pool Exhaustion in n8n
I’m designing a high-throughput data ingestion workflow in n8n using the PostgreSQL node. The workflow processes 10k+ records per minute and performs batch inserts with ON CONFLICT DO UPDATE (UPSERT).I’m running into deadlocks, connection pool exhaustion, and occasional duplicate writes when multiple executions run concurrently. I’m also seeing performance drops when transactions stay open too long.
I’ve tried batching and limiting concurrency, but the issues still happen under load.
What would be the best way to handle transactional integrity, retries on deadlock, and connection pooling in n8n for this kind of workload?
Hi @Keira_Becky
Every workflow execution runs independently. So if several executions fire at the same time, each one opens its own connection and transaction to PostgreSQL. When they all try to UPSERT at once, they start competing for the same rows — that’s where the deadlocks and connection exhaustion come from.
n8n isn’t doing anything “wrong” it’s just doing exactly what it’s told, in parallel.
Try this fix is simple:
Slow down concurrency
Use smaller batches
Add retries for deadlock errors
At this scale, stability usually comes from controlling how fast n8n runs not just tuning the database.
Okay thanks @Niffzy
