Highlevel connection
Highlevel node requires email address for ‘Create or Update’ contact. Is there a way to change this so it can use just the phone number?
  • Running n8n via n8n cloud
The Highlevel API requires email for contact creation - this is an API limitation, not an n8n issue,
  1. Create a dummy email using phone numbers:
Add a Function node before Highlevel:
return {
  json: {
    ...item.json,
    email: item.json.phone + '@placeholder.com'
  1. Try the “HTTP Request” node to directly use the Highlevel API with phone-only lookup:
POST https://api.highlevel.com/api/contacts/lookup
Body: {"phone": "{{$json.phone}}"}
This bypasses the n8n node’s validation requirements.
