This is a mid-level to senior role. Applicants must be able to work either on Eastern U.S. time or have significant overlap with that time zone. For anyone interested in applying, read the full job description (linked at bottom of post) then follow these instructions exactly:
ONE:
Send me an email at [email protected] with the subject line: “Automation & AI Systems Engineer – [your first and last name]”. For example, “Automation & AI Systems Engineer – Matt Mason” (don’t include the quotes).
TWO:
In that email, share the following three things:
Your résumé / CV (PDF preferred)
A brief description of 3 automations you’ve built. For each one, share (1) the basic flow (e.g. “slack trigger, set node, LLM with simple memory, reply in slack”), (2) what problem it solved, (3) the tools/systems involved (e.g. n8n, Slack, Asana, Shopify, Klaviyo, APIs), (4) what you did to turn it from proof-of-concept into a production-ready workflow, and (5) if possible, a screenshot of the workflow (redact sensitive information).
Answer this question: What are you most proud of in your career and why?
THREE:
Do NOT send me a DM. All DMs will be ignored.
Full job description here:
https://docs.google.com/document/d/1k8pmCf9DLEG4FASE-NHDrOlqZZyW7SaBwEt4_oI4LGI/edit?usp=sharing
I don’t have that years of experience… but I have a direct experience of working with clients for projects.
I am one of verified n8n template creator(iamvaar) - search for “iamvaar n8n” on Google.
And I am a full stack developer too and here is my recent portfolio: projects.md · GitHub
I just won’t be building workflows… I built custom n8n nodes too for business and companies(these examples nodes are just my way of payback to n8n community and there are many others but I can’t reveal them as I signed NDA
) : https://www.npmjs.com/package/n8n-nodes-pdfbro
https://www.npmjs.com/package/n8n-nodes-ocrbro
https://www.npmjs.com/package/n8n-nodes-ttsbro
And I started posting very little of my work on YouTube:
https://youtube.com/@blankarray
I build some automations for myself too because I believe in the value I provide… (I get automated client leads for finding n8n projects):
And here is my linktree:
iamvaar | Linktree
Thank you for your reply. This is a mid- to senior-level role, so the years of experience listed in the job description are required. Wishing you the best!
UPDATE: We are no longer accepting new applicants. (I would edit my original post to put this update at the top, but I’m not seeing a way to do that.)
Maybe edit the title and add [Closed]? Not sure though
ModernAI is no longer accepting applications for this position, but I don’t seem to have the ability to modify or delete my original post. Tagging a few mods for help.
Mods – deletion is preferred, if possible (because inevitably people will still continue to apply even if the post is edited to say “CLOSED”). Thank you for your help!
@liam @Shireen
@Jon_James @bartv Would very much appreciate some mod help here, please.
Deletion is preferred, if possible (because inevitably people will still continue to apply even if the post is edited to say “CLOSED”). Thank you for your help!
I’m Naresh, an AI Systems Engineer and the founder of Piorate Ventures. I specialize in building agentic orchestration—essentially creating autonomous systems that don’t just ‘run’ but actually reason and recover from errors. I’ve spent the last 2.5 years building production-grade n8n and Python workflows for global agencies, and I’m ready to help you architect the core engine of this company as a technical partner.
Hi Matt,
Resume attached. Here are three production automations:
CEO Intelligence Dashboard: Scheduled trigger → BigQuery → Claude
analysis → Slack. Solved: CEO needed real-time insights from 15+ systems.
Tools: n8n, BigQuery, Claude, Slack. Production: error handling, retry
logic, monitoring alerts.
Multi-AI Content Engine: Form → RAG (Supabase) → Multi-agent (Gemini,
OpenAI, Claude) → Output. Solved: Brand-consistent content for Samsung/Vivo.
Tools: n8n, Supabase, LLM APIs. Production: cost tracking, rate limiting,
fallback models.
Newsletter Automation: RSS → GPT curation → SendGrid → 1,000+ subscribers.
Solved: 4h daily manual work eliminated. Tools: n8n, OpenAI, SendGrid.
Production: retry mechanisms, duplicate detection, failover.
Career highlight: Built Suno’s AI infrastructure from zero to 50+ production
systems serving Fortune 500 clients (Samsung, Vivo, Danone). Proudest moment:
seeing skeptical teams become AI advocates after experiencing reliable tools,
not demos.
EST-aligned, ready to contribute.
Best,
Iuri
[email protected] | +55 11 95174-9848 | iurireisportifolio.lovable.app
