[HIRING] Claude API + n8n Engineer — 31-Agent Business Intelligence System | Remote
Hi Priyanshu,
Apologies — my previous message was addressed to the wrong name. It was meant for you.
Your VPN and Opus answers are solid — exactly the right approach for this build. Ready to move forward. Next step is a mutual NDA and service contract before we exchange specifics.
Please send me your standard NDA and service agreement, or let me know if you’d prefer to work from ours. My direct email is [your email] — let’s continue off-platform from here.
Best,
Louis
Hi Louis,
Appreciate the clarity — this is exactly the level of system design I enjoy working on.
Live example (relevant):
I recently built a multi-source pipeline combining CRM, email, and enrichment APIs into a structured outbound intelligence layer.
Key parts:
  • n8n orchestration with async execution + retry handling
  • structured output enforcement (JSON schema validation before downstream use)
  • separation between ingestion, transformation, and action layers to avoid cross-contamination
  • logging + observability for debugging agent behavior at scale
Credential isolation (mental model):
I treat credentials as strictly scoped resources at the workflow level, not agent level.
  • Each agent operates within its own isolated workflow context with dedicated credential bindings
  • No shared credential store across agents — only shared outputs, never access
  • Cross-agent communication happens through a controlled intermediate layer (DB / queue / structured storage), not direct calls
  • Sensitive operations (e.g. financial APIs) are executed in tightly scoped sub-workflows with minimal surface area
  • If needed, I enforce isolation further via separate n8n instances or environment-level separation depending on risk level
This ensures zero leakage while still allowing coordinated orchestration at a higher level.
Happy to review Phase 1 scope and align on execution.
— Muhammad
Muhammad,
Solid response — the credential isolation model and pipeline architecture are relevant.
Before we move to a call, two follow-up questions specific to our environment:
  1. Security (deeper): Our agents connect to QuickBooks, internal financial APIs, and portfolio management systems — all behind a corporate VPN. Walk us through exactly how you would establish and maintain secure remote access to a client’s internal systems. Specifically: how do you handle VPN credential management, and how do you prevent your local environment from becoming a security surface?
  2. Claude Extended Thinking: One of our agents uses Claude’s extended thinking mode for complex multi-step reasoning across financial and operational data. Have you implemented it? If yes, describe a concrete use case. If no, describe how you would approach it.
    Also — we work fixed price for Phase 1 (4 agents, fully tested, documented, deployed). What is your number?
    Please reply in writing. If all three check out, we’ll schedule a 20-minute call.
    Best,
Louis
Hi Louis,
Understood — answering directly.
Security (VPN + internal systems):
I treat the client environment as the only trusted execution layer — not my local machine.
Access setup:
  • Use a dedicated isolated environment (client-provided VM or hardened cloud instance)
  • VPN is configured only on that environment (not on my personal device)
  • Enforce IP restrictions + device-level access where possible
Credential management:
  • VPN credentials stored only within the secured environment (never locally)
  • API credentials handled via environment variables / secret manager
  • Separate credentials per system (QuickBooks, internal APIs, portfolio systems), all scoped with least privilege
  • No credential sharing across agents — access is injected only at execution level
Operational security:
  • My local machine acts as a thin client (SSH / remote access only)
  • No sensitive data stored or processed locally
  • Logs and outputs remain inside the secured environment
  • Credential rotation + access revocation handled at environment level
Net: agents and workflows run inside your boundary; my device never becomes part of the attack surface.
I haven’t deployed extended thinking in production yet, but here’s exactly how I would implement it in your setup:
  • Restrict usage to L3 synthesis layer (where multi-step reasoning adds value)
  • Inputs come from L1/L2 as validated, structured JSON (no raw/uncontrolled text)
Prompt structure:
  1. Signal extraction → identify key metrics, anomalies, and changes across entities
  2. Reasoning layer → enforce step-by-step analysis (why it matters, relationships, confidence levels)
  3. Output layer → generate a structured intelligence brief (consistent schema, not freeform)
Key control:
  • Strict schema validation before and after L3
  • Guardrails to prevent hallucinated metrics (cross-check against inputs)
  • Cost + latency managed by limiting extended thinking to high-value runs only
The leverage is not the model itself — it’s the structure of inputs and constraints around it.
Phase 1 (4 agents, fixed price):
$2,000 total
Includes:
  • agent build (L1/L2/L3 aligned to your architecture)
  • integration with required data sources
  • error handling + retries
  • testing (functional + edge cases)
  • documentation for operator handoff
  • deployment-ready workflows
LinkedIn: https://www.linkedin.com/in/mbz1415/
— Muhammad
@Trefle Profile - Trefle - n8n Community
Hi Louis,
I’ve read the full thread — I know the architecture is 33 agents across 5 tiers, not 31, and that Phase 1 is scoped to 4 agents against an already-defined structure. I’m not going to re-explain what you already know.
Answering your three questions directly:
  1. Fixed-price Phase 1 scoping
    Deliverable is defined before a single line is built: 4 agents, credential-isolated, tested against your actual data sources, deployed on your Mac Studio, with a documented operator handoff (Loom + Notion). I don’t start the clock until we’ve aligned on the exact input/output contract for each agent in writing. If scope creeps, we pause and re-sign — not renegotiate mid-build.
  2. VPN + credential security
    I work inside your boundary, not from my local machine. You provision a VM or SSH access to a hardened environment within your network. VPN credentials live only there. QuickBooks and Sage Intacct credentials are stored as environment variables scoped per workflow — never shared across agents, never on my device. My local machine is a thin client. Sensitive data never leaves your perimeter.
  3. Opus extended thinking — concrete prompt structure
    Built a 3-source synthesis layer for a retail client: internal margin data, competitor pricing, and demand signals. Prompt structure: labelled observation blocks per source → explicit instruction to identify conflicts between sources before drawing conclusions → output schema enforcing a confidence score and source attribution per recommendation. The critical design was forcing the model to surface disagreement rather than average it out. Extended thinking made it flag contradictions that Sonnet would have silently resolved. That changed actual pricing decisions in 4 of 8 weekly briefs.
    Rate: $1,800 fixed for Phase 1. Same scope as above.
    Happy to get on a 20-minute call.
    https://axonyx.framer.ai/
    pmediaaryan@gmail.com
Hey - this is exactly the kind of system I work on.
Quick context on me:
  • I run self-hosted n8n on Docker in production right now, not as a hobby project - real infrastructure with Postgres, Grafana monitoring, cron scheduling, Telegram alerts when something breaks
  • Claude API (Sonnet and Opus) is my daily driver - I have 4 production workflows that make sequential Claude calls with proper error handling, response parsing, and retry logic
  • Python + cron - I write scheduled scripts that run alongside n8n, been doing this for years
  • Credential management - env vars in Docker, n8n’s built-in credential store, nothing hardcoded ever
On the specific pieces you mentioned:
  • QuickBooks - haven’t integrated it directly, but I’ve worked with plenty of REST APIs that follow the same OAuth + paginated endpoints pattern. I’ll read their docs and have it working fast
  • Multi-source intelligence synthesis - my Lead Intelligence workflow does exactly this: pulls data from multiple APIs, runs it through sequential Claude calls (analysis → research → synthesis), routes by priority. Same architecture your L1/L2/L3 layers would need
  • Source verification between layers - I build validation and filtering logic in JavaScript Code nodes between every AI call, so garbage doesn’t flow downstream
I document everything and build for handoff - clean naming, inline comments, README per workflow. I’ve managed a team of 6+ devs so I know what “operator-friendly” actually means in practice.
Portfolio with 4 production systems: GitHub - penkayone/n8n-automation-portfolio: Production-grade n8n workflow automations — AI lead intelligence, competitive market monitoring, customer support bot, multi-API company research. 4 enterprise workflows, 62 nodes, 9 AI calls, 40+ tech signatures. · GitHub
Happy to start with Phase 1 (4 agents) and prove the quality before scaling to all 31. Available to discuss scope and timeline whenever works for you.
Anton
Telegram: @antongoloskokov
Email: An.goloskokov@gmail.com
Hi!
I’ve reviewed your project for the Caribbean-based portfolio. Building a 31-agent intelligence system requires more than just connecting APIs—it requires a solid data orchestration layer, and n8n is the perfect engine for this.
Why I’m the right engineer for this build:
  • Production Claude API Experience: I don’t build “chatbots”; I build Agentic Workflows. I specialize in multi-layer architectures where Sonnet handles L1/L2 data extraction and Opus (with extended thinking) manages L3 strategic synthesis. I know how to handle context window optimization and prompt chaining for complex multi-source intelligence.
  • n8n Self-Hosted Mastery: I have deep experience with self-hosted n8n environments. I understand the nuances of running on dedicated hardware, managing local resources, and integrating Python/Cron for heavy lifting that standard nodes shouldn’t handle.
  • Enterprise Integrations: I’m comfortable with QuickBooks and REST APIs. I understand that when pulling sales briefs or hotel rates, data integrity and error handling are non-negotiable. If an API fails, the system must log it, retry, and alert, not just stop.
  • Clean & Documented: I deliver operator-friendly systems. You’ll get clean credential management, async processing to prevent bottlenecks, and full documentation so your team can actually manage the agents after handoff.
My Background: I am a developer (JavaScript/Python/SQL) at heart. I’ve built “AI Content Factories” and Lead Gen systems that function as autonomous departments. You can see my engineering style here: https://mikedevai.netlify.app/
Phase 1 Ready: I’m ready to start with the first 4 agents and prove the reliability of the architecture. I’m also comfortable working with your specific sectors (Hotels, Jewelry, Spirits).
Contacts:
Let’s hop on a call to discuss the L3 synthesis logic and the Mac Studio deployment.
This is a solid build — and I’ll be upfront: I’ve worked extensively with Claude Haiku-class models in production, and I design systems to stay reliable even without relying on heavy models like Opus.
My focus is not just model capability, but system architecture that compensates for model limitations.
What I bring:
  • Multi-agent system design (production mindset)
    I structure agents into layers (ingestion → validation → synthesis), with strict role separation so even lightweight models like Haiku can perform reliably.
  • Claude optimization (Haiku-first strategy)
    Instead of depending on a single powerful model, I design:
    • chained reasoning across agents
    • validation loops (agent-to-agent cross-checking)
    • structured outputs to reduce hallucination
      This allows Haiku to handle more complex workloads than expected.
  • n8n as orchestration backbone
    I build self-hosted workflows with:
    • async execution
    • retry + fallback logic
    • modular agent pipelines
    • clean credential isolation
  • AI Unlimited routing approach
    I typically design systems that can flexibly switch between models when needed:
    GPT-4o mini, GPT-5 mini, Claude Haiku — depending on cost/performance targets.
  • Finance/data workflows
    Comfortable handling structured data pipelines similar to QuickBooks/Sage environments, including validation and reporting layers.
How I’d approach your Phase 1 (4 agents):
  1. Build ingestion agents (QuickBooks / APIs)
  2. Add validation + source filtering layer
  3. Use multi-step synthesis instead of single heavy model calls
  4. Output structured reports ready for decision-making
Goal: a system that runs consistently, not one that depends on a single expensive model.
If later you introduce Sonnet/Opus, I can plug them into the architecture without redesigning the system.
Happy to sketch a quick architecture for your hotel + retail use case if needed.
This project matches my stack exactly.
I have been building production Claude API systems since early 2024 — 9 MCP servers in TypeScript, 162 n8n community nodes published under @velocity-bpa, and a 45-node autonomous pipeline that uses the same Sonnet/Opus split you described (Sonnet for generation, Opus for architecture and L3 reasoning). I run Claude as the operational layer across all of it with n8n handling orchestration underneath.
The multi-entity intelligence synthesis you are describing — pulling from QuickBooks, Sage Intacct, Duetto, and Gmail into layered analysis — is exactly the kind of system I build. Clean credential management, async workflows, and operator-friendly handoffs are how I deliver everything. My clients do not need to understand the internals to use what I ship.
Happy to start with Phase 1 and let the work speak for itself.
Portfolio: johndrefahl.com | velobpa.com
GitHub: Velocity-BPA (John Drefahl) · GitHub
Email: john@velobpa.com
hey Trefle - this is a solid architecture. few thoughts from running something similar in production:
the L1/L2/L3 tiering with Sonnet vs Opus is the right call, but you’ll want a routing layer that can dynamically escalate based on confidence scores, not just predefined rules. we found that saves ~40% on API costs without sacrificing output quality at L3.
for the QuickBooks + Duetto integration specifically - credential rotation and token refresh across 31 agents gets hairy fast. worth building a central credential broker early rather than retrofitting later.
also re: the Mac Studio deployment - have you stress tested concurrent agent execution on that hardware? 31 agents with extended thinking enabled can spike memory usage in ways that aren’t obvious during single-agent testing.
we actually build and manage multi-agent systems like this as a service (orchestration, monitoring, the whole stack). if you’d want a second pair of eyes on the architecture before you commit to a hire, happy to do a quick review call: https://cal.com/princeps/poly-digital-workforce
either way, cool project. the wine and spirits data layer sounds fun to work with.
Hi Louis,
I’ll answer the questions you’ve been asking applicants upfront.
Proof: I run OpenClaw, a 6-agent Claude system for my own agency. Max handles strategy, Ash ops, Lex dev, and three more across client-facing functions. n8n orchestration, Telegram triggers, custom memory architecture to preserve context across sessions. Self-hosted on a production VPS. GitHub: jasherjoshuachan (Jasher Joshua A. Chan) · GitHub
Phase 1 scoping: Fixed price for fixed scope. 4 defined agents = 4 deliverables. I quote per agent based on complexity: n8n workflow build, Python scheduling, tested handoff, documentation. Happy to give you a number after a 30-min call.
Credentials and access: Environment variables, never hardcoded in workflow configs. For a Mac Studio local setup, system keychain or .env. Remote access via whatever VPN you already run. I don’t need persistent access after handoff.
Opus extended thinking: Same tiered pattern you described. Sonnet at L1/L2, Opus at strategic synthesis. Thinking token budget depends on task complexity — calibrating that is part of the build, not an afterthought.
One more thing: I’m a certified QBO ProAdvisor. The QuickBooks integration layer is familiar territory.
— Jasher jasherchan.truehubsolutions.com
Production Claude API + n8n self-hosted is exactly my stack. I’ve built a 5-department multi-agent intelligence system on OpenClaw with n8n orchestration that monitors data sources, synthesizes reports, and delivers structured outputs automatically. Running in production, not a demo.
I work with Claude API daily - prompt engineering, structured outputs, multi-step agent logic. I understand the difference between L1/L2 routing and L3 synthesis with extended thinking.
Clean credential management, async delivery, documented handoff - that’s how I work. I take ownership from spec to deployed solution.
What’s the scope for Phase 1 and timeline?
Hey Trefle
This looks more like an dashboard then a simple automation. We`ve recently built a dashboard that connect different API and extracts data and not only pulls data but make a fine report out of it. My area of expertise include custom logic based automations that pull data from different API and combine them in a single platform. In this dashboard, you can have hell of errors and that is where we come in the play. While using custom logics, we keep in mind the possible errors that can come while you are asleep.
You can book an exploration call with me and I can guide you exactly how i will handle this project!
Best Regards
Hi Trefle,
The 31-agent plan is big enough that the first pass should prove the operating pattern, not the whole system.
The paid proof slice I would want first:
one source system → one Claude/n8n analysis path → verified brief rows + review/error ledger
For example, QuickBooks weekly sales brief or a Duetto rate-monitor slice, with the source records preserved, the model output reviewable, and every skipped or uncertain item written to a queue instead of disappearing.
I run these as written, fixed-scope builds. If that narrow proof is useful, send the target first agent, one redacted source sample, and the expected operator handoff shape. I can say whether a first $3,000 priority sprint is realistic before any access is shared.
Public demo of the review-queue/error-log style:
Alex Reed
WorkflowPatch
alex@workflowpatch.com
Hi,
I am interested in supporting this build, especially the Phase 1 scope.
This is close to the type of system I am building and working toward: multi-agent business workflows, API integrations, structured decision layers, data retrieval, reporting, and operator-friendly automation that can be maintained after handoff.
For the first 4 agents, I would focus on making the architecture stable before scaling:
  • clear agent input/output contracts
  • separate L1/L2/L3 reasoning steps where needed
  • Claude API calls with structured prompts and predictable parsing
  • n8n workflow logs, retries and failure branches
  • credential separation and documentation
  • handoff notes so operators understand how each agent works
I do not see this as a demo-style build. The important part is reliability: clean workflow design, controlled API usage, test cases and documentation.
I am based in Spain, available for remote async work, and would be happy to review the Phase 1 spec and propose a practical implementation plan.
Reach me here or at: jorgelg1177@gmail.com
Hi Trefle,
Your stack maps to my daily work — n8n self-hosted + Claude API + Python orchestration. I haven’t built at 31-agent scale, but the patterns line up:
Production Claude API in n8n — every product in my Gumroad shop runs Claude or Groq in the orchestration layer:
  • WhatsApp AI Invoice Agent: Claude → structured invoice output → PDF.co → Drive archive. Customer-facing, real edge cases.
  • Marketing Automation Suite: 5 n8n flows, LLM-driven lead scoring + Google Ads anomaly detection + Slack briefings. Sold & supported.
  • Email Re-engagement PRO: Groq with Claude fallback, dynamic content across a 6-month drip.
Honest answers to your filters:
  • n8n self-hosted production — daily.
  • Sonnet/Opus split — Sonnet heavily; Opus extended thinking I’ve prototyped, not run at L3-synthesis depth. I’d budget a paid spike to de-risk before phase 1 commit.
  • QuickBooks specifically — haven’t touched QBO API. But I’ve built around the same shape (OAuth2, paginated endpoints, webhook consumers) on Google Workspace, WooCommerce, Twilio.
  • Documented handoff — every Gumroad product is operator-friendly, not engineer-only. Habit, not afterthought.
For Phase 1, I’d ask for a 30-min scoping call before quoting fixed-price — sizing 4 agents honestly beats guessing. Open this week.
-– Sefa
