I run a signage manufacturing business in Australia. Over the last while I’ve built an AI agent stack — OpenClaw agents on a hardened self-hosted VPS, with n8n coming in to handle the deterministic stuff (tracking signs through our production line, Telegram photo capture, monday.com dashboards). One production box is live and healthy. Now I’m scaling to more instances and I’ve hit the limit of doing all the technical work myself. I need a proper technical partner for the long run.
**First job — a paid trial task, fixed price:**
I’ll give you a fresh throwaway VPS (Hetzner, Ubuntu 24.04). Turn it into a hardened OpenClaw host:
- OpenClaw installed properly — pinned version, local npm, dedicated non-sudo user, running under systemd
- Hardened: SSH key-only, UFW, fail2ban, everything loopback-bound except :22
- Monitoring: CrowdSec + Netdata — or make the case for whatever you’d use instead. I care more about your reasoning than the exact tools.
- Secrets in env files, 0600, never in unit files or shell history
- Hand back: the working box, a short runbook of what you did and why, and a screen recording of the important parts (Loom or whatever — voiceover is great, no camera needed). I archive these so we can repeat and reference everything later.
If the trial goes well there’s plenty of ongoing work — more agent boxes, n8n workflows for the production line, and on-call fixes when something breaks. I’m after someone with serious hours in this space, who’s patient enough to explain things step by step. Screen recording the significant work is standard on every job here, not just the trial — that’s how I keep it all documented.
**To apply, reply with these four things:**
1. **Answer this one:** a staff member sends a photo of a finished sign to our Telegram agent. In 3–5 sentences, how would you get that photo stored and linked to the right job record? No single right answer — I want to see how you think.
2. One link to the most relevant thing you’ve built. Just one, the closest match — not your whole portfolio.
3. Your fixed quote for the trial + hourly rate for ongoing work.
4. Your timezone and how fast you can usually jump on something urgent.
Fair warning: if your reply doesn’t answer question 1, I won’t read the rest. I’m getting a lot of copy-paste pitches lately and I’d much rather a short honest reply from a real practitioner than a polished brochure.
And even if you’re not the hire this round — I’m building a network of good automation people and I keep names. Happy to talk to plenty of you.
