Looking to hire a project-based automation and AI expert to think, plan, and deploy several use-cases (some are pure automation, others require AI) for a distribution business.
Looking for someone based in Egypt for proximity and face to face meetings if needed.
Apart from that I’m also a full-stack developer with the right Gen AI experience, which makes me a solid plus for your team[but right now only vibecoding]
Check my recent gen ai projects… I built a native Android automation agent too. It’s worth a look:
I can build complex AI automations directly in code, not just inside n8n
I recently started posting my n8n work on YouTube with explanations:
I’m an Automation Engineer specializing in n8n, Make.com, AI workflows, API integrations, CRM automation, and business process automation.
While I’m based in Nigeria rather than Egypt, I’m comfortable working remotely and scheduling regular call sessions whenever needed to stay aligned on project planning, deployment, and ongoing improvements.
I’ve sent you a DM with more information about my experience and relevant project examples.
This sounds very aligned with the automation and AI work I do.
I help businesses map manual processes, identify which workflows should be automated, and build AI-powered systems using tools like n8n, Make, Zapier, OpenAI/Claude/Gemini, Google Workspace, Airtable, CRMs, and APIs.
For a distribution business, I can help with use cases such as order processing, inventory alerts, vendor/customer communication, invoice handling, reporting, lead follow-ups, and AI-assisted internal workflows.
I’m not based in Egypt, but I can work closely through calls, screen sharing, and clear documentation. If remote collaboration works for you, I’d be happy to discuss the use cases and suggest a practical automation roadmap.
Muttawa, I’m Misha, an n8n and AI automation developer. For a distribution business, I’d map out each use-case—whether it’s routing orders from a spreadsheet or Telegram into an accounting system, or using AI to extract data from delivery receipts and invoices—and wire them as reliable n8n workflows with validation, retries, and logging so you don’t lose a single record. Since you’re based in Egypt, I can show up for a planning session in person, then deploy everything on a VPS or locally. I keep builds simple, test them live with real data, and make sure you can hand them off to your team without needing a developer every time. If you want to talk through the first use-case and agree on a scope, ping me. Portfolio: https://mikedevai.netlify.app/ | Telegram: Telegram: Contact @hely_chatbots | WhatsApp: +375293761570
