How are companies actually using AI agents to automate actions in business systems?
How are companies actually using AI agents to automate actions in real business systems?
I’m researching how companies are actually using AI agents or AI-powered workflows to take actions in real business systems.
I’m especially interested in cases where AI does more than generate text and can actually change something in tools like:
  • HubSpot
  • Shopify
  • Stripe
  • Gmail
  • Databases
  • Internal systems
  • Other SaaS tools
The kind of workflow I mean
Trigger
AI Agent / LLM
AI decides what action to take
n8n / custom code / MCP / API
HubSpot / Shopify / Stripe / Gmail / database
Action happens
Log / verify the result
The pattern that actually survives contact with production is write, read back, then log. The agent picks the action, n8n performs it, and the next step re-reads the record (or queries the API) to confirm the change landed before the run is marked successful - a 200 from HubSpot/Stripe is not proof the field changed. Give every action an idempotency key so a retry can’t double-create or double-charge, and keep irreversible steps (refunds, deletes, money movement) behind a human approval or at least a reversible staging state. Scope each credential to the minimum the agent needs, because an LLM holding a broad token will eventually call something you didn’t intend. And log the decision, the tool call, and the verification result together - otherwise you can’t tell a silent no-op from a real success when someone asks.
