Greetings @robertwilliam yes, n8n can do all of that. Here’s a structure I’d start from.
Receiving orders: a Webhook node set to respond immediately, then hand the work to a sub-workflow so a slow restaurant call never makes your app time out. Add header auth on the webhook, and save each order with its order ID as a unique key, so a retried webhook can’t create a duplicate.
Restaurant notification: send the message, then pause on a Wait node that resumes when the restaurant accepts. If it times out, escalate to a second contact or mark the order for review.
Customer updates: a Switch node on the order status (confirmed, preparing, picked up, delivered) feeding the WhatsApp Business, Telegram or Twilio node. Keep message templates in one place so wording changes don’t mean editing five workflows.
Delivery assignment: query available drivers from your database, pick the closest with a Code node, offer the job, and reassign if there’s no accept within a set time.
Failed notifications: turn on “Retry on Fail” for the messaging nodes, then use an Error Trigger workflow that logs to a failure table and alerts a human.
Treat the order state in a database as the source of truth, with n8n as the orchestrator. That makes replays and debugging much easier.
Pond AI could help build and run a setup like this. It’s an AI engineer on call that designs, builds and keeps custom agents and workflows running, and it sketches the architecture for free first, with a 7-day refund on custom builds.
Are you starting from scratch, or is there an app and restaurant system already in place? If it sounds useful, I’d be glad to introduce you to the founder or the team.
Disclosure: I’m affiliated with Pond AI
