<!-I’m working on a food delivery app and want to use n8n to automate order updates. For example, when a restaurant accepts an order or a delivery partner picks it up, n8n should trigger notifications and update the order status.
Would webhooks be the best approach for connecting the app with n8n, or is there a better workflow design for handling these events?- Hey! The fastest way to find solutions is by using the
search function at the upper right.
If your question hasn’t been asked before, please follow the template below. Skip the questions that are not relevant to you.
You can post in any language - we’ll translate your post for you!
- n8n version:
- Database (default: SQLite):
- Operating system:
