<I’m exploring how to use n8n to build an AI chatbot for a food delivery application.
The chatbot would need to answer questions about menus, restaurant availability, order status, delivery times, cancellations, refunds, and common customer issues. Ideally, it should also be able to retrieve the customer’s current order information from a database and provide a response based on real-time data.
I’m wondering what would be the best workflow architecture for this.
Would you use an AI Agent with tools for database/API lookups, or would it be better to use separate workflows for order tracking, restaurant information, payments, and customer support?
I’d also like to know how others handle human escalation when the AI cannot confidently resolve a customer’s issue.
What would be the recommended n8n approach for building this type of chatbot?!-- Hey! The fastest way to find solutions is by using the
search function at the uI’m exploring how to use n8n to build an AI chatbot for a food delivery application.
What would be the recommended n8n approach for building this type of chatbot?pper right.
If your question hasn’t been asked before, please follow the template below. Skip the questions that are not relevant to you.
You can post in any language - we’ll translate your post for you!
- n8n version:
- Database (default: SQLite):
- Operating system:
One AI Agent with tools, not four workflows. Split it and you need a router that is itself a classifier, and every misroute is a dead end.
Give the agent Call n8n Workflow Tool entries, one per capability: getOrderStatus, getMenu, cancelOrder, requestRefund. Each sub-workflow starts with an Execute Workflow Trigger set to Define using fields below so the agent sees typed inputs, and the tool Description is what actually picks it, so write it for the model.
Menus and policy text go in a vector store tool, order data never does. It goes through a Postgres or HTTP Request tool queried live, keyed by the customer id you pass in the agent’s system message, never by an id the user types.
Escalation: skip confidence scoring, it does not exist. Add an escalateToHuman tool the model can call, and in the system prompt say to call it when it cannot answer from a tool result. Also escalate on refunds above your threshold and on any second consecutive failed tool call. Memory node keyed by session id, or context dies each turn.
You need to create 2 n8n workflows and 1 tool.
I’m not sure where your existing information about menus, restaurant availability, order status, delivery times, cancellations, refunds, and common customer questions is stored.
First workflow: You need to take your existing data and create a vector database from it. I recommend using Supabase.
Your data - AI embed Agent - Supabase vector database
Second workflow:
webhook - AI agent - reply webhook
Tools: supabase + order
1 tool - order
Turn order status, delivery time, and cancellations into standard tools.
In your existing chatbot workflow, add a webhook. Then connect it to the second workflow. You only need to run the first workflow to update when menus, availability, or FAQs change.
I’d suggest using an AI Agent to understand the customer’s query and route it to separate n8n workflows for order tracking, restaurant information, and support requests. This makes each part easier to test and maintain.
For real-time order status and delivery estimates, the workflow should fetch data directly from the relevant API or database instead of relying on the AI to guess. I’d also add authentication checks and validation rules for sensitive actions like cancellations and refunds.
If the bot cannot resolve an issue confidently, it should pass the conversation to a human support agent along with the order details and conversation history.
If you’re also comparing different AI solutions for chatbot use cases, AI chatbot tools can be another resource to look at. For the n8n workflow itself, though, I’d start with FAQs and order tracking, test them thoroughly, and then gradually add refunds and cancellations.
