i have been using n8n for automating tasks and sometimes i need to work with SSL certificates i usually have crt files that must be converted into pfx format to be used in certain nodes i inspired from the idea of crt to pfx conversion positively because it seems like a simple step that could make workflows much smoother a crt to pfx conversion is the process of taking a certificate file in crt format which typically contains the public certificate and optionally the private key and combining it into a single pfx file which can then be used in systems that require a pfx container for authentication or encryption this process ensures that the certificate and private key are packaged together in a format that can be easily imported and recognized by applications i want to understand how this conversion can fit naturally into n8n workflows so that i do not have to rely on external tools or manual steps i am curious if there is a way to automate this process within n8n and manage the certificates safely while passing them between nodes i usually save them temporarily in environment variables or encrypted credentials and i wonder if anyone has methods to make this smoother and more reliable
Here’s how to handle CRT to PFX conversion in n8n:
1. Use the **Crypto node** ([docs.n8n.io](Crypto | n8n Docs)) to manage certificates securely. It supports signing/encrypting with private keys.
2. For file conversion, combine:
**HTTP Request node** to fetch the CRT file
**Function node** to convert formats (using OpenSSL commands via `child_process`)
**Convert to File node** ([docs.n8n.io](Convert to File | n8n Docs)) to output as PFX
Store sensitive data in n8n credentials ([n8npro.in](Secure Sensitive Data in n8n Workflows)) and use environment variables for temporary storage.
For OpenSSL commands reference, check [ssl.com](PEM, DER, CRT, and CER: X.509 Encodings and Conversions - SSL.com) on certificate formats.
