How can I store images in a knowledge base (vector store), and what is the process for retrieving them later?
I’m working on building a knowledge base using a vector store and would like to store images alongside text data. My main questions are:
  1. How can I add images to the vector store?
• Should I convert images into embeddings first, or is there a way to store them directly?
• What tools or integrations (e.g., OpenAI, Pinecone, Weaviate) work best for handling images?
  1. How can I retrieve the stored images later?
• If images are embedded as vectors, how can I ensure accurate retrieval?
• Are there specific workflows or nodes in n8n that can help with this process?
Any guidance, best practices, or examples would be greatly appreciated! :rocket: Thanks in advance!
Tip for sharing your workflow in the forum
Pasting your n8n workflow
<your workflow>
Make sure that you’ve removed any sensitive information from your workflow and include dummy data or pinned data as much as you can!
There are probably many ways to do this but this workflow template might be a good place to start? Generating Image Embeddings via Textual Summarisation | n8n workflow template
