How can I use my data sources, whether files or databases, with an AI agent? I always encounter problems. Is there an easy local method?
Hello @ayman2011a,
One trick with AI agents is to pass a value into a tool connected to the agent. Much of the time, the tool is simply a sub workflow copied into the tool.
Here’s an agent that references files in a google drive. the get_document tool is simply a workflow with two nodes an execution and a google doc tool.
Hope this helps!
Robert
If this answer helped solve your issue, feel free to mark it as the solution so others can benefit from it too!
Thanks @rbreen for the suggestion, That’s a clever approach. Unfortunately, I tried this with Gemini, but it didn’t work as expected. It seems like the model doesn’t handle this setup well.
Appreciate your input!
By the way, have you tried a workflow with Gemini and PostgreSQL that works without issues? I’d love to know if you have any insights on that!
Hi @ayman2011a,
I havent used gemini, but let me give it a try! Just signed up for gemini the other day. I’ll publish it here as a workflow if I get it to work.
Best,
Robert
@ayman2011a ,
I got this to work with gemini. Here’s the same flow. It can be tricky to implement. Upload your workflow if you are having errors.
Best,
Robert
