How could TheHive alert get Observables without case ID? the flow doesnt work at all, it is because of Observables requires case ID instead of alert ID, the flow is definitely wrong. without case promoted by alert, it is not able to retrieve the Observables, and then it is not able to get to run the executer, then you wont get the alert is true or false…
https://community.n8n.io/uploads/default/original/2X/4/4f73bbb0a2c1dbf169cf9c9029ab419617a227e6.jpeg
