How delete unnecessary lines, replace column names and fix encoding in CSV file
Help is needed again.
Capture_04
Can you please share the file somewhere, else it is hard to help you.
sent the file in a personal message
Hm, it always seems to mess up the encoding. So I had to do the json to binary conversion and the parsing of the CSV file manually. But this should work now. Did add comments to explain what is happening:
Works great! Thank you, Jan!
Great to hear that it helped!
