Is there a way to further process items discarded by a filter node or do I have to replace it with a different type of node (e.g. if node)?
Iād use a Switch node that lets you route the discarded items instead of losing them.
If the filter is binary - yes or no / true or false - then if will do the trick, otherwise the switch is the way to go.
