Hello, I’d like to create a workflow that captures the images from every new post in a subreddit and sends them to me on Telegram. Can you help me with that?
Hi @ibere Welcome to the community!
Here’s a very quick example workflow to get you started - you’ll need to edit this as needed for your use-case
Thank you so much
@EmeraldHerald Bot keep sending the same photos over and over; can you make changes to prevent them from sending the same photos?
You could probably use something like this workflow template, modified for Reddit:
Could you check that out for some ideas and let me know where you get stuck?
