How do I stop my n8n workflow from running twice?
Hi everyone,
Im trying to setup a workflow in n8n but for some reason it runs twice when I only expect it to run once. I checked the trigger but still cant figure out what is causing it.
Is there something I might be missing here? Any help would be appreciated.
A workflow running twice doesn’t always mean the trigger itself is faulty. I’d first check whether n8n is creating two executions or whether one execution is processing the same item twice.
A few things worth checking:
  1. Execution history: Compare both executions’ start times and inspect their trigger inputs. Two separate executions usually point to duplicate trigger events or multiple active trigger paths.
  2. Workflow configuration: Check whether the workflow is active while you’re also testing it manually, and verify that the same event isn’t being received by two webhook or trigger paths.
  3. Item flow: If there’s only one execution, inspect the item counts after each node. A previous node may be outputting multiple items, causing downstream actions to run more than once.
  4. Retries and external events: Check whether the source system retries its webhook or sends duplicate notifications.
If the workflow creates important side effects—such as orders, payments, or database records—don’t rely on trigger settings alone. Use a stable event or idempotency key and enforce uniqueness in persistent storage so duplicate deliveries cannot create duplicate business actions.
Could you share which trigger you’re using and whether the execution history shows two separate executions or one execution with duplicate downstream actions? That will help narrow down the actual cause without rebuilding the workflow.
Quick check: in Executions, is it two runs or one run doing the thing twice?
Two runs + Webhook/Form → deactivate, wait a bit, activate once (and don’t Test while it’s already active). Also worth a look: another workflow on the same webhook path.
