How I Built an AI Video Content Pipeline with Gemini Omni and n8n
<I recently built an automated AI video generation workflow using n8n and Gemini Omni, and wanted to share the approach with the community.
The goal was simple:
  • Generate short-form video ideas automatically
  • Create video prompts with AI
  • Send prompts to Gemini Omni
  • Generate videos
  • Store assets automatically
  • Publish content to social platforms
Workflow Overview
  1. RSS Feed / Trend Source
  2. AI Research Agent
  3. Prompt Generator
  4. Gemini Omni Video Generation
  5. Asset Storage
  6. Social Media Publishing
Why Gemini Omni?
The biggest advantage for this workflow was consistency.
Compared to many video generators I tested, Gemini Omni handled:
  • Character consistency
  • Multi-scene storytelling
  • Prompt adherence
  • Video-to-video refinement
    especially well.
Example Use Cases
  • Product marketing videos
  • Social media content
  • AI-generated explainer videos
  • UGC-style ads
  • Educational content
Future Improvements
I’m currently experimenting with:
  • Multi-agent prompt optimization
  • Automatic trend detection
  • SEO keyword clustering
  • Multi-platform publishing
    Has anyone built something similar using n8n?
    I’d love to see how others are automating AI video production pipelines.!-- Hey! The fastest way to find solutions is by using the :magnifying_glass_tilted_right: search function at the upper right.
    If your question hasn’t been asked before, please follow the template below. Skip the questions that are not relevant to you.
    :brazil: :france: :south_korea: :germany: You can post in any language - we’ll translate your post for you!
The RSS-to-video pipeline is a solid approach - using Gemini Omni directly in the workflow removes a whole layer of manual prompt-to-video handoff. One thing worth adding once you scale up: a Wait node between the Gemini Omni generation step and the social publishing step, so bursts of trending RSS items don’t hit rate limits or flood the publishing queue all at once.
the part id separate is generation from delivery. give every video one content id, poll Gemini until the file is actually finished, then store a public URL that will still work when the publish step runs. after that, make the caption per platform instead of reusing one generic block
i work with blotato. id keep research, approval, job status and retries in n8n, then hand the approved video and captions to blotato for publishing. save the returned post ids back on the same content id so a timeout only retries the failed destination, not the whole generation pipeline
Hey @Nano_Banana1
Build end-to-end AI video automation workflows using n8n, Gemini, and multi-agent AI to generate, manage, and publish high-quality content at scale. The solution will be reliable, easy to extend, and optimized for consistent video production across multiple platforms.
• Build AI video generation workflows in n8n
• Automate trend research & prompt creation
• Integrate Gemini for video generation
• Auto-store assets & publish to social platforms
• Optimize with multi-agent AI workflows
I like the separation between generation and publishing here.
I took a similar approach with text + image content: generate the content first, then treat delivery as a separate layer that can be changed depending on the business.
I think this becomes especially important when one workflow needs to serve several markets or platforms, because each destination eventually needs different formatting.
Have you considered generating platform-specific versions from one master content object before the publishing stage?
I built an AI video content pipeline using Gemini Omni and n8n to automate the process of turning ideas into engaging video content. The workflow connects AI-powered content generation with automation, helping with tasks such as creating scripts, developing video concepts, organizing assets, and preparing content for publishing. For example, an engaging gaming project like Moto X3M Pool Party can benefit from this type of streamlined content workflow, making it easier to produce and manage promotional videos at scale.
