How I can work with wait node on webhook url call?
I have a simple workflow with wait node and I want to resume the flow on a webhook call. And I have decided to use a third party webhook caller for the flow to be resumed.
But, as the webhook is dynamically generated so I don’t know what url I must use in the third party service. because the executions number is being changed on every run.
And what do you suggest I should use for external api calling system?
no any error right now
  • n8n version:1.22.4
  • Database (default: SQLite):default
  • Running n8n via (Docker, npm, n8n cloud, desktop app):cloud
  • Operating system:windows
Hi @Kelash, n8n uses this execution ID to identify which execution to resume when receiving a webhook. It provides an expression that will always reference the correct URL for every single run {{ $execution.resumeUrl }} and which you can send to external systems.
This really is up to you. Even an email or Telegram message can do the job. Check out this workflow for an example:
