I have a node that fans out into two parallel branches. Each branch starts with a Data Table “Get” node, and both Get nodes get the exact same input item from the shared parent node.
One of these parallel Get nodes runs fine. The other one just does not execute at all. The funny thing is that the only difference between the two nodes is the table they point to. Everything else is identical, same input, same operation, same settings.
I have already checked the obvious things:
- The table the failing node points to is verified to exist.
- The data inside that table is verified, it is there.
- I added a condition (filter) to the node, did not help.
- I tried relocating the node on the canvas, did not help.
- I suspected the node simply did not have enough time to run (some kind of timing/race), so I checked that carefully. That is not it.
- I recreated the node from scratch, did not help.
- I reconnected it to the table, did not help.
- I changed the table selection from “Choose from list” to “By ID”, and also to “By name”, did not help.
The one thing that somehow did make it run was moving the node much further down the chain, roughly 10 nodes later. I then tried moving it only 5 nodes down, and 1 node back, and it stopped working again. So the position in the chain seems to matter, which I do not understand for a node that just reads a table.
This becomes a real failure when a downstream node references the node by name with $('Get node B').all(). Since that node never executed, the reference returns nothing, while the sibling Get node on the same input works perfectly.
Why would one parallel Get node refuse to execute while its sibling with the same input runs fine, and why does only moving it far down the chain fix it?
No error on the Get node itself, it simply does not run. The downstream node then fails because the referenced node was never executed.
(Get node A: returns its rows as expected. Get node B, same input: no execution, no output.)
- n8n version: 2.25.7
- Database (default: SQLite): default n8n
- Running n8n via (Docker, npm, n8n cloud, desktop app): n8n cloud
- Operating system: n8n cloud
