How long does it take’s to get approval into the marketplace or how can i build private app in my n8n
Saw a post from n8n employe that mentioned around 2 days. But it was in October. Would probably say it’s a bit more now. The service has really popped of.
Is there any way we can use my own package privately? can you share some documenation
Do you mean a custom node? In that case, this url below is what your looking for.
Ore do you mean like custom packages like sharp?
some people are using skool and gaining subscriber to see there workflows they create, marketplace can take awhile now but always worth being on, very busy they are now, if using skool this is mainly workflow based, and the link Grok sent, u can create community packages with custom nodes, which others can use etc. Hope that helps explain bit more.
Hello,
We have submitted our application called issuebadge a digital badge issuing platform. could you please look into it, is our application got reviewed? or any update? how can we get to know about it.
Hello any update how we will be listed on n8n need someone help who can get listed in in n8n n8n-nodes-issuebadge - npm
