How long does template review as n8n creators usually take?
Hi everyone :waving_hand:
I recently submitted a couple of workflow templates through the Creator Portal and they are currently “Under review.” I was wondering how long the review process usually takes before a template gets approved and published?
Is it usually a few days, a week, or longer? Just trying to understand the typical timeline so I know what to expect.
Thanks!
Hi @wayphantomme This should not take more than 2 weeks you can reach out to support@n8n.io with details of your submitted flows and they would confirm more things about the situation or if there is something missing there.
