HOW TO:AWS Automated Infrastructure Build & Operations Workflow
This is still under consideration, so I’d appreciate any advice.
:bullseye: Objectives
  • Full automation from error detection to notification and resolution
  • Error summarization and automated fixes with an AI Agent
  • Achieve automatic updates of Infrastructure as Code (IaC)
:counterclockwise_arrows_button: Flow
  1. EC2 Error Occurs
    • An error occurs on the EC2 instance
  2. Error Detection & Trigger
    • CloudWatch detects the error and triggers Lambda
  3. Error Forwarding
    • Lambda sends error details via HTTP POST
  4. n8n Webhook
    • n8n webhook receives the request and initiates processing
  5. Error Analysis with AI
    • LLM Chain generates a prompt → Gemini invoked → Error details summarized
  6. Google Chat Notification
    • Error summary automatically sent to Google Chat
  7. Automated Error Fix
    • AI Agent generates a fix proposal
    • Infrastructure code automatically updated via GitHub MCP
:hammer_and_wrench: Tech Stack
  • AWS CDK: Infrastructure as Code for AWS environment
  • n8n: Workflow automation after error detection
  • Gemini AI: Error summarization and prompt processing
  • Google Chat: Notification channel
  • GitHub MCP: Automatic updates of infrastructure code
:light_bulb: What This Enables
  • End-to-end automation from incident → notification → resolution
  • Faster error analysis with AI
  • Continuous alignment with the latest state through IaC auto-updates
:warning: Considerations
  • Accuracy and risk management of automated fixes
  • Scope of application (all errors vs. specific patterns)
  • Rollback strategy design
